04-03-2011 12:04 PM - edited 03-19-2019 02:40 AM
Hi, I've just installed Connection 8.5.1ES16.11900-16 My problem is with
my call handlers. If I create a new handler, then edit the closed greeting, I can then enable it, and record my prompt ect - all ok.
If however, I check the "During Greeting / Ignore Caller Input" check box and hit save, the "Status" and "Callers Hear" radio buttons blank out, also the "Play/Record" section greys out
I then cannot go back and remove the "During Greeting / Ignore Caller Input" check box, because when I hit save, I get a blank screen with "Internal Error, try again"
Solved! Go to Solution.
04-04-2011 05:39 AM
04-04-2011 05:39 AM
04-04-2011 06:50 AM
Thanks Rob!!
That was exactly the issue.
gmb
04-04-2011 11:56 AM
Hey George,
You are always welcome
Cheers!
Rob
