unity connection 8.6 compatible with cucm 11.5?
baselzind
Level 6
Level 6
im upgrading a cucm from 8.6 on a vm to 11.5 , but it is already integrated to a "8.6.2ES25.21900-25" unity connection , is the unity connection "8.6.2ES25.21900-25" compatible with cucm 11.5?
Rob Huffman
Hi there,
You should be good to go;
Supported Version Combinations for Unity Connection and Cisco Unified Communications Manager
Table 17 Supported Version Combinations for Unity Connection and Cisco Unified Communications Manager
Cisco Unity Connection Cisco Unified Communications Manager
8.5 and Later
11.5(1), 11.0(1), 10.5(2), 10.5(1), 10.0(1), 9.1(2), 9.1(1), 9.0(1), 8.6(2), 8.6(1), 8.5(1)
From;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/compatibility/matrix/b_cucclientmtx.html#id_24435
Cheers!
Rob
EDIT: +5 for my friend JB for beating me to the punch here.
Jitender Bhandari
Yes it is compatible you dont have to worry you can upgrade the CUCM to latest 11.5.X.
(Rate if it helps)
JB
Just to confirm you can see below
8.5 and Later
(Rate if it helps)
JB
Rob Huffman
Hi there,
8.5 and Later
From;
Cheers!
Rob
