Unity Connection 8 call handler question
Hey everyone--this is kind of an odd question to me but i'm hoping someone else has come across this--I've got a client that I recently installed a Unity Connection 8 VM server as part of a new IPT system.  One of the functions of the auto-attendant is to host a 'job hotline' where they list jobs currently open at the organization.  They've got it broken down into 4 or 5 categories, but in order to list all the jobs (without details...) they need more than the minute and a half of record time that's there.  Is there a setting somewhere to increase the amount of record time?
Rob Huffman
Hi there,
This can be changed
The Greeting Length for a Call Handler is determined by the COS of the person recording the Greeting. Have a look;
Class of Service Greetings Settings
The class of service greetings setting specifies the maximum length of greetings.
Subscribers > Class of Service > Greetings Page
Field Considerations
Maximum Greeting Length in Seconds
Select the recording length allowed to subscribers assigned to this COS for recording greetings.
The range is 1 to 999 seconds; the default is 90 seconds.
Cheers!
Rob
Great stuff--I found the setting in the CoS for one of the users. One thing I noticed and I can't find in the UCxn docs is does that setting apply only when doing the greetings over the phone or should it show up in the GUI as well? Not sure if a service needs reset or something for it to take effect?
Scott Jones
Hi Scott,
Nothing should need to be reset or restarted
We do our Greetings over the phone, but this new
Greeting length should work via the GUI as well. Did you
try a Greeting over 90 seconds?
Cheers!
Rob
