Unity Connection 8 Cluster replication
lance-kadish
Hi I have a CUC cluster that is giving me replication problems;
The dbreplication looks ok see below:
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_CUC_PUB8_0_2_40000_1    2 Active   Local           0
g_CUC_SUB8_0_2_40000_1    3 Active   Connected       0 May 29 15:51:20
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: Replication status command started at: 2012-05-29-17-39
     Replication status command COMPLETED 519 tables checked out of 519
     No Errors or Mismatches found.
     Use 'file view activelog cm/trace/dbl/sdi/ReplicationStatus.2012_05_29_17_39_56.out' to see the details
DB Version: ccm8_0_2_40000_1
Number of replicated tables: 519
Cluster Detailed View from PUB (2 Servers):
                                PING            REPLICATION     REPL.   DBver&  REPL.  REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    STATUS          QUEUE   TABLES  LOOP?  (RTMT) & details
CUC_PUB  X.X.X.X    0.031   Yes     Connected       0       match   N/A    (2) PUB Setup Completed
CUC_SUB  Y.Y.Y.Y    0.936   Yes     Connected       0       match   N/A    (2) Setup Completed
BUT
when I run the show cuc cluster status command i see:
admin:show cuc cluster status
Server Name     Member ID  Server State  Internal State  Reason
CUC_PUB  0          Primary       Pri Active      Normal
CUC_SUB  1          Secondary     Sec Active      Normal
Database replication is not active
nikshah
are you using DNS by any chance.
try running utils diagnose test and see if the validate network test passes successfully.
also try running utils network host and it should all resolve correctly
I am using IP address and not FQDN
hey lance,
can you run a utils ntp status on the pub and the sub..
also kindly attach the output of utils diagnose test from pub and sub
