Unity Connection 8.X Partitions and Search Spaces
I'm designing a CUC 8.X deployment that will have many sites.   In CUC, I need to be able to segment each site into seperate partitions yet want to give my ports access to evey site's partition via a "global" search space.   My concern is that I cannot find in Cisco docs if there are limitations to the number of partitions that can be added to CUC search spaces similar to the CSS restrictions in CUCM.   Does anyone know what the limitations are with CUC with regards to partitions and search spaces?
Glenn
Brad Magnani
Hi Glenn,
UC 7.1 introduced the capacity for 200 Search Spaces and 200 Partitions:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/release/notes/712cucrn.html#wp429742
Hope that helps,
Brad
