Unity Connection 8
kiru
Can Unity Connection handle country of origin identification for call routing to AA?
Jonathan Schulenberg
No it cannot. The only time I've seen this work is using the Call Center Express or IP IVR product. In that system you can parse the caller ID and use a large select case to modify the behavior per-country.
