Unity Connection 9.x options for secure messaging
BILL PETERSEN
We are looking to roll out a large Unity connection deployment but have some pretty tight security requirements.
We would like to notify someone via email that they have a message but don't send the actuall message to email.
We would like to forward the message between phones but keep the message secure.
Can someone help me understand the options for that?
thanks
2 Accepted Solutions
Chris Deren
Sure, secured messaging is a feature of UCXN that you can enable, you can also enable email notification that will alert folks about messages waiting.
Check out UCXN security guide for more details:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/security/guide/9xcucsec070.html
HTH,
Chris
There is no implication on the notifications if the message is secured. The notification simply alerts you about the message as you still need to access it from secured device/application.
HTH,
Chris
Chris Deren
HTH,
Chris
Thanks Chris
So if you are using notification but keeping on vm on the vm server, what is the behavior of the notification when using secure messaging?
thanks
HTH,
Chris
