Unity Connection - Adding comments to Voicemail Message
Vaijanath Sonvane
For unity connection subscriber, is it possible to add a comment to the message that is being forwarded? Is it possible to retain that added comment when a message to be sent from one subscriber to multiple extensions, names, or distribution lists?
VJ.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Bradford Magnani
I think you may be looking for the recording an introduction feature?
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag130.html#wp1068229
Hope that helps,
Brad
Bradford Magnani
Hope that helps,
Brad
Hi Brad,
Thanks for your help. This answers my question.
VJ.
