10-31-2012 02:27 PM - edited 03-19-2019 05:49 AM
For unity connection subscriber, is it possible to add a comment to the message that is being forwarded? Is it possible to retain that added comment when a message to be sent from one subscriber to multiple extensions, names, or distribution lists?
VJ.
Solved! Go to Solution.
10-31-2012 02:46 PM
I think you may be looking for the recording an introduction feature?
Hope that helps,
Brad
10-31-2012 02:46 PM
Hope that helps,
Brad
11-01-2012 05:22 AM
Hi Brad,
Thanks for your help. This answers my question.
VJ.
