Unity Connection - Broadcast Messaging
srivatsan04
I have a CUCM 11.5, CUC 11.5 and 2 client PC VMs which has CIPC installed in it. I created 2 users and given authorization for one user to send and update broadcast message from send message settings. I configured System Call Handler with an extension (+12012012203) and pointed the Standard Greetings Conversation to Broadcast Message Administrator.
Also created the DN for that extension in CUCM and forwarded all calls to voicemail.
From one PC, when i dial the assigned extension i hear "Welcome to Cisco Unity Connection Broadcast Message Administrator, enter your ID followed by #". At this period when i enter # for both ID and PIN, i hear "Welcome to Cisco Unity Connection Messaging System, you may dial an extension any time.....".
Even when i enter the correct user ID and PIN, i hear invalid entry. But, the PIN i entered is what i use while entering the Mailbox.
I don't know how to record and send broadcast message. Can anyone help me out in this?
The issue is solved, the problem is I entered the wrong ID. Need to enter the Extension number as user ID.
6 Replies 6
Chris Deren
does the user have "User Can Send Broadcast Messages to Users on This Server"set under "Send Message Settings"?
Yes, as i mentioned above. I request everyone to please read the information fully and suggest a solution.
That would do it :-)
hi  Srivatsan04,
after enter Broadcast Messaging as administrator, record a message, do you know how to just send it  to a dedicated group (not all users)?
thanks.
Check out this tool:
https://www.ciscounitytools.com/Applications/CxN/BroadcastMessageManager/Help/Cisco%20Unity%20Connection%20BMT.htm
it allows you to defined via CSV file who should get the message, I don't believe Unity natively allows for that flexibility as broadcast message would go to everyone.
