04-23-2010 02:48 PM - edited 03-19-2019 12:50 AM
It is posible to remove DNS resolution in a cluster AFTER the cluster is set (AKA: both unity Connection were installed using DNS resolution)?
Version 7.1
04-23-2010 04:48 PM
The installation rules for DNS are that if you do not configure it on initial install, then you cannot enable it post-installation without rebuilding the system. My inclination is that the reverse is also true. I also tested trying to remove the DNS configurations on a 7.1(3b)SU1 CUC server in my lab and there doesn't appear to be a valid command to do this. You can change the primary and secondary DNS servers; however, you cannot disable DNS.
Hailey
Please rate helpful posts!
04-23-2010 06:33 PM
If you take out the DNS server(s)s you will disable DNS resolution.
- Alex
04-23-2010 06:38 PM
Alex,
Have you attempted to do this on a 7.1 server? If you attempt to set a blank DNS server, you get a CLI error for a missing, required configuration parameter...at least I did.
Hailey
04-23-2010 06:39 PM
There is a command for clear DNS server.
- Alex
04-23-2010 06:43 PM
What command would that be?
