Unity connection - DiRT backup error
joel.paulraj
Hi I'm changing my unity connection to another hardware box, I have the same software versions installed.
When I try to backup my existing server, it does not backup "UnityDirDBBackUp.sql" & "UnityMbxDB1BackUp.sql".
This is the Backup log.
8/17/2006 10:30:47 PM: Backing up UnityDirDB SQL table to: E:\New Folder\Streams\UnityMbxDB1\2006.07.27-14.11.02.796\
8/17/2006 10:30:47 PM: (error) in cmbBackup routine:[Microsoft][ODBC SQL Server Driver][SQL Server]Cannot open backup device 'E:\New Folder\Streams\UnityMbxDB1\2006.07.27-14.11.02.796\UnityDirDBBackUp.sql'. Device error or device off-line. See the SQL Server error log for more details.
[Microsoft][ODBC SQL Server Driver][SQL Server]BACKUP DATABASE is terminating abnormally. number= 0
8/17/2006 10:30:47 PM: Backing up UnityMbxDB1 SQL table to: E:\New Folder\Streams\UnityMbxDB1\2006.07.27-14.11.02.796\
8/17/2006 10:30:47 PM: (error) in cmbBackup routine:[Microsoft][ODBC SQL Server Driver][SQL Server]Cannot open backup device 'E:\New Folder\Streams\UnityMbxDB1\2006.07.27-14.11.02.796\UnityMbxDB1BackUp.sql'. Device error or device off-line. See the SQL Server error log for more details.
I've attached the full log file.
Can someone please help.
Joel
lindborg
Is E a mapped drive by any chance? I'm guessing it is.
Try backing up to a local drive and then copying the backup off box - most times when I see these errors it's because the account associated with the SQL services do not have rights to update the remote folders - it's not the account you're logged in as, it's the one associated with the SQL services here.
The easiest way to do this is to use the "two hop" backup method - this is why I added that option.
Hey thanks Lindborg,
E: is a local drive, I was reading about this two hop backup and I also tried backing up to C: drive, still I get the same error.
Well, those errors are being returned from SQL on a standard backup request - those aren't DiRT errors so I'm not sure what else to suggest. I guess I would try doing a backup to a short path name just to be sure the space in the path isn't tripping you up (it shouldn't be - I just tested my connection 1.2 install and it handles this fine).
Also, I don't suppose anti virus software or CSA is in play here? Just a thought...
I upgraded the DiRT version from 2.0.6 to 2.0.7 and it worked...thanks for ur help
