Unity Connection Dormant Mailboxes
pdillon
Large customer wants to cull some of its licensed mailboxes that are no longer being used. As they are not integrated with LDAP, many former users have not been removed from Unity and some existing users have mailboxes but may not use them at all.
Is there any easy way to determine say a set of mailboxes that have not had activity for a period of time? And then this list could be deleted....
Paul
Rob Huffman
Hi Paul,
There are a number of results in this great "Unity" tool that can help in determining unused (dormant) accounts in Unity Connection. Here are a few;
Mailbox unread messages older than 60      days
. The number of messages currently in the users’ mailbox that are unread (new) and arrived 30 or more days ago. This can be useful in finding mailboxes that are not being used.
NOTE: This requires that the time of the local client and the time of the Connection server be in agreement (they do not need to be in the same time zone, of course).
Time      of Last Call. Indicates the date and time the user called in to check messages last. This can be handy for finding out which boxes have not been access at all or which ones have not been      accessed in a long time. This value is converted into the local time of the computer you are running User Data Dump on
  • User generated mailbox activity detected      in the last 60 days. How outputs a 1 if there's been any user generated activity detected for each mailbox and 0 if there has not been any in the last 60 days. This can be helpful for finding      mailboxes that are no longer in use.       Note that mailboxes that have been created less than 60 days ago      will get a -1 value for this field.
  • User generated mailbox activity detected      in the last 90 days. How outputs a      1 if there's been any user generated activity detected for each mailbox      and 0 if there has not been any in the last 90 days. This can be helpful for finding      mailboxes that are no longer in use.       Note that mailboxes that have been created less than 90 days ago      will get a -1 value for this field.
  • User generated mailbox activity detected      in the last 180 days. How outputs a      1 if there's been any user generated activity detected for each mailbox      and 0 if there has not been any in the last 180 days. This can be helpful for finding      mailboxes that are no longer in use.       Note that mailboxes that have been created less than 180 days ago      will get a -1 value for this field.
From this awesome tool;
Cisco User Data Dump
http://ciscounitytools.com/Applications/CxN/UserDataDump/Help/UserDataDump.htm#_Toc320093163
Cheers!
Rob
Rob Huffman
Hi Paul,
Cheers!
Rob
Hi Rob
Do you know if the values of "User generated mailbox activity detected" includes activity from Cisco Viewmail ? We have the same situation and we believe quite a number of voicemail accounts can be deleted but we need to confirm this however running these reports we are not 100% sure it does include Viewmail as there are definitely accounts from users who are still working for the company but they show up on this report.
Thanks, Carl Ratcliffe
Preston Lancashire Engand
Hi Carl,
I wish I had a 100% answer for you but I'm afraid I don't as we don't use viewmail. I believe that the reports using CUDD only capture the TUI useage numbers. If it were me I would setup a couple of test accounts on CUC and play with the reports using a "known" testbed. The other thing I always do if I'm unsure when deleting mailboxes is to just re-assign them a phantom DN for 30 days or so before the final removal. This way they can be easily reinstated with the original DN/extension if the mailbox was removed in error and the user won't have any setup to do over.
Cheers!
Rob
Thanks Rob
It seems no matter what report you run it only shows TUI activity and Cisco Viewmail is not recorded as Activity so we may go down the oldest unready mail although this isn't as useful as it maybe the voicemail box is unused and simply doesn't have any old voicemails.
