05-05-2014 07:03 AM - edited 03-19-2019 08:09 AM
I have only 1 no's of unity connection , when I shut my cucm publisher 9.1 , unity connection 9.1 doesn't works with cucm subscriber.
Also I get a choppy voice when I play from the phone or when I press a message button the greeting from the system is chopping.
thanks
Solved! Go to Solution.
05-05-2014 07:17 AM
Have you configured both servers in CUC??
Does the CUCM side integration has the CUCM group with both servers??
05-05-2014 07:17 AM
05-06-2014 12:25 AM
Dears
When i press a message button from my phone i get a choppy audio,
05-05-2014 08:25 AM
Hi Adam,
Java is most correct here (+5 J-man!)
Can you check these settings in CUC for the "Secondary" server config. This would add the Sub
to the list of available CUCM servers
Step 32 On the Edit Servers page, do the following substeps if the Cisco Unified CM cluster has secondary servers. Otherwise, skip to Step 33.
a. Under Cisco Unified Communications Manager Servers, click Add.
b. Enter the following settings for the secondary Cisco Unified CM server and click Save.
Table 6-16 Settings for the Cisco Unified Communications Manager Servers
# Field | # Setting |
# Order | # Enter the order of priority for the Cisco Unified CM server. The lowest number is the primary Cisco Unified CM server, the higher numbers are the secondary servers. |
# IP Address or Host Name | # Enter the IP address (or host name) of the secondary Cisco Unified CM server. |
# Port | # Enter the TCP port of the Cisco Unified CM server that you are integrating with Cisco Unity Connection. We recommend that you use the default setting. |
# TLS Port | # Enter the TLS port of the Cisco Unified CM server that you are integrating with Cisco Unity Connection. We recommend that you use the default setting. |
# Server Type | # Click Cisco Unified Communications Manager. |
Cheers!
Rob
