Unity Connection from norstar
dshumake
Level 4
Level 4
I have a norstar voicemail system that will be changing over to unity connection 10.5.2.
is there a non painful way to export the voicemail from one system to the other.  I am talking 3 - 5 mailboxes only.  HR group....
thank
-ds
Brandon Buffin
No easy way. Does the Norstar have desktop/unified messaging? If so, you could connect to the mailboxes with a mail client and save the messages out as .wav files. If not, the only other option would be to play the messages via speakerphone and record with an external device/PC and then save to .wav.
Brandon
