Unity connection greeting issue
Yazen Alaa
I have unity connection 8.X , i want to create greeting as following as below :
"Welocome to xyz company for english press 1 for arabic press 2 , "
when press "1 " for english
you will hear greeting
" press 1 for Marketing department
press 2 for sales department
0press 0 to go to operator"
when press "2" for arabic
you will hear the same above but in arabic  language
"press 1 for Marketing department
my question is how many call handlers i will create and for what exactly ?
and how the call handlers  it will be ???
I will do standard and closed for this setup or i dont need ????or only call handlers that set
please i need help ASAP
thanks and regards
garethpeart
Level 3
Level 3
You'll need a total of 3 call handlers:
1. The Options greeting (English or Arabic)
2. The English Call Handler
3. The Arabic Call Handler
The easiest way is to create the 2nd and 3rd call handlers first and the Options Handler last ( So you can easily point to the language call handlers in your caller input)
I would only do the closed greeting on the Options handler and have that greeting recorded in both English and Arabic with the after greeting option going to the operator voicemail box
5 Replies 5
garethpeart
Level 3
Level 3
it is done and I found the best solution  , i did create 3 call handlers
one for welcome greeting
second one for arabic
third one for english
thanks for all
Hi Yazen,
Can you please share your script with me, I have to do the same scripting.
Shahzad
CUC has no scripts, it's just call handlers, and caller input to configure a simple AA, the topic has been discussed thoroughly in CSC and I even have a small config guide in my UC FAQ
java
if this helps, please rate
your are right, am looking for script which gives choice to user to select either English or Arabic keeping default language Arabic.
I have already prepared one script which need little modification.
will appreciate if you could help me out.
Shahzad
