unity connection licensing on A-flex
plp_pnlr
I'm confused on the new licensing of CUCM especially on unity connection. On  a professional license on cucm it says unity connection license is included. although there still an option to choose unity connection as add-on. Also what is the features included on the unity connection in a Professional License is it for vociemail only? How about  the auto-attendant features?
3 Accepted Solutions
TONY SMITH
Are you referring to Flex 3.0, top level part A-FLEX-3?  If so then Named User Professional includes a Unity Connection voicemail licence.  The Unity Connection Add-On would be used if you need more mail boxes, for example if you have NU Enhanced some of which need voicemail.
As @TONY SMITH  explained Add-on license is for adding more license if you need, When adding named users on CCW, did the system ask you to select  the Add-on License ? if you miss anything on A-flex , you get a warning on the right hand side of the CCW. And also on CCW you have option to verify it.
You will be able to run the AA with professional license.
Response Signature
This is a table that explains it.
7 Replies 7
TONY SMITH
Response Signature
Hi Nithin,
Thank you for your reply. How about with enhanced and access license, will I be able to run AA without add on unity connection license?
You need unity license if you are going with enhanced or access.
Response Signature
sanjinz85
Is it possible to order additional Enhanced licenses along with A-FLEX-P-UCXN (voicemail)?
As this post is marked as solved and is multiple years old it is recommended that you create a new to ask your question.
Response Signature
