Unity Connection not Recognizing Alternate Names
ahochau_2
Greeings,
Using Unity Connection 8.6(2), 8.6.2ES69.23900-69 to be exact, it does not appear to be recognizing alternate names.  I have added global nicknames as well as adding alternate names to the mailbox and when I try the name, it is less than sucessful.  Any suggestiongs?
Thanks in advance!
yahsiel2004
Level 7
Level 7
What exactly is the issue? Are you unable to apply an alternate name or is Unity not speaking the alternate names?
Yosh
HTH Regards, Yosh
