unity connection problem
born.jason
i  have a little problem with MWI. If i have new phones it doesn`t work.  It works only if i enable a notification device and make a call to the  voicebox. After that i can remove the notification device and it works  with the phone. But it is annoying to enable on every voicemailbox this  feature and disable it after that.
Any suggestions?
Bryan Shapess
Jason,
What version of Unity Connection do you have?
How are you adding the users?  From the web page as standard users, through a Bulk tool or importing from AXL and LDAP?
When you say you have to add a notification device, you mean like send a SMTP notification, or a phone notification?
What you are describing is not nornal behavior.
When you say MWI doesn't work for new phones, if you call and leave them a messge (when they are broken), if you go to the "Message Waiting Indicators" page for that user, do you see a line there?  Does it say On or Off for current status?
