Unity Connection SMTP Notification Message
David Wagner
Hey,
we have CUC 7.1.3. I want to change the smtp notification message. Is it possible to remove the "Info:" string from the message body?
Tommer Catlin
I dont believe you can.   You can only change the subject line in the message. (System Settings)
