Unity connection SQL Exception errors
markhayek
    Running 8.5.   Replication seems to be in sync at the time, the voice network map shows no RED. The USN Sent = USN ACK, so looks good there.   Now we are seeing a few of these errors, what do they mean ?  Is it jsut that there is no recording there ? I look , and I hear a recorded name and a greeting. How can I be certain the mailbox is operating correctly.  Is there a list of these error codes posted ?
** error:
10:25:17.062 |9106,UserCreateOrModify,,-1,-1,Database unitydirdb access error: Failed calling csp_GlobalUserModify. (DisplayName= Adriana Davalos). TECHNICAL DETAILS: java.sql.SQLException: Object not found.  Object = [StreamFile], Table = [tbl_StreamFile], Colu
10:25:17.062 |9106,UserCreateOrModify,,CuReplicator,0,Exception Catch: Failed calling csp_GlobalUserModify. (DisplayName= Adriana Davalos)
10:25:17.062 |9106,UserCreateOrModify,,CuReplicator,0,Error Message=Object not found.  Object = [StreamFile], Table = [tbl_StreamFile], Colu
0 Replies 0
