Bookmark
Subscribe
1197
Unity Connection Subscriber
jasb_cistel
I add an subscriber for Unity Connection but it doesn't work.
On my publisher i had the second server, in the post installa of second server i say that it's the subscriber
When post install finished i can see my users and configuration .....
I stop the publisher but the subscriber dosesn't work.
I have this information " Communication is not functioning correctly between the servers in the Cisco  Unity Connection Cluster, go to tools/ Cluster management" ans "The Cisco Unity connection cluster subscriber server has changed to Primary Status (failover has occured"
When i go to Tools/Cluster management for my prublisher i can see 16 ports but for subscriber 0 it's my problem ?
5 Replies 5
Shadi Shami
Level 7
Level 7
did you create ports for the 2nd server, Telephony Integrations > Port?
Thank you,
Shadi
Thanks for you answer, by adding port to subscriber it works but i still have the message error "Communication is not functioning correctly between the servers in the Cisco  Unity Connection Cluster, go to tools/ Cluster management"
Are you still getting the error?
can you check db replication and ntp status:
show perf query class "Number of Replicates  Created and State of Replication"
utils ntp status
As a fast suggestion, I recommend restarting the publisher, wait 5 minutes, then restart the Subscriber.
Thank you,
Shadi
Thanks for your replies.
I restarting the publisher and after 5 minutes the subscriber but still the same error until evrything it's working.
Result of of show perf:
==>query class :
 - Perf class (Number of Replicates Created and State of Replication) has instances and values:
    ReplicateCount  -> Number of Replicates Created   = 603
    ReplicateCount  -> Replicate_State                = 2
And show ntp for publisher:
ntpd (pid 28882) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
*10.1.2.5    95.81.173.155    3 u    8   64   77    0.331    3.873   7.473
synchronised to NTP server (10.1.2.5) at stratum 4
   time correct to within 124 ms
   polling server every 64 s
Current time in UTC is : Thu Apr  9 07:57:04 UTC 2015
Current time in Europe/Paris is : Thu Apr  9 09:57:04 CEST 2015
And for subscriber:
ntpd (pid 28317) is running...
*10.1.1.1      10.1.2.5      4 u   78  128  367    0.278   -3.459   6.852
synchronised to NTP server (10.1.1.1) at stratum 5
   time correct to within 586 ms
   polling server every 256 s
Current time in UTC is : Thu Apr  9 07:57:49 UTC 2015
Current time in Europe/Paris is : Thu Apr  9 09:57:49 CEST 2015
DB Replicatioln looks good. If the IP address/ hostname has not been changed recently, I have nothing to add.
