Unity Connection Version 1.2(1) CallHandlers Issues
zawadzkij
Currently Running Unity Connection 1.2(1). I have created a Basic Auto Attendent (Opening Greeting) with a few caller inputs going to other submenus(Callhandlers). When I press 1 via the Opening Greeting I get the canned recording message from Unity "I'm Sorry" then it hits the respective call handler greeting "recording" I created. This happens on all callhandlers that I have a direct send to greeting for. Any thoughts. Thanks.
Jaime Valencia
did u recorded the greeting under greetings???
it sounds to me you recorded them under the recorded voice on the main profile
javalenc
if this helps, please rate
java
javalenc,
I'll have to confirm when I get back onsite. I'll keep you posted. Thanks.
