Unity Connection VPIM Bridgehead for CUC/CU hybrid environment
rwolfe
I have an environment in which there are two CU clusters on 4.05 without VPIM licenses.  AMIS is the current transport mechanism for a legacy Centrex integration.  We are moving to Unity Connection and TAC has mentioned that it is possible to use the new Unity Connection server as the VPIM bridgehead server, controlling licensing of VPIM for the entire cluster, including the unlicensed 4.05 clusters, negating the need for VPIM licenses for the two leagcy clusters.
Has anyone validated that this will work?  I'm going to test it in the lab, but if anyone can confirm or deny, that will be a good start.
-rob
