unity connection web admin user locked!
fly
Level 2
Level 2
Hi, all,
    we just modify unit connection admin password (web admin),  but after modify password, we can't login again. it was said locked.
    we using same admin username admin for cli and web admin, is this problem?
  unity connection is based on linux version is 8.5.1.10000-206 so can't using pwreset tool to reset password , because it is for windows.
    we lost install cd of unity connection
    How can i unlock for unity connection
   thank you!
Tom
Jaime Valencia
See here for the any of the above
http://docwiki.cisco.com/wiki/CUCM_FAQ#OS_.2F_CLI
You can also refer to the CLI command reference from CUCM, as they share most of the commands.
java
if this helps, please rate
we can managemet access by cli, the username is same : admin. as we access through web
but I don't know what is different with web access.
i found a document,is this right
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-connection/68400-unity-conn-password-recovery.html
thank you, Jaime
