unity connection
tkavithas87
The call manager is integrated with unity connection.here the ip phone is getting the voicemail and also MWI is working.but cannot hear the voicemail after login through the phone message button.Its going to to a greeting(System call handler)what should be enabled to hear the voicemail?
thanks
kavi
The default direct routing rules in priority order are Attempt SignIn (1) and Opening Greeting (2).  Attempt SignIn sends callers to the "Attempt Sign In" conversation.
Hailey
Please rate helpful posts!
Jaime Valencia
Have you changed the call routing rules for direct calls??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Call routing rule is set.
here it is set send call to opening greeting.so its directing to opening greeting.what should i set there to here the voicemail?
thanks
Hailey
