Unity Connections - Miu Errors
adignan
Level 8
Level 8
Opening a TAC case but if anyone has anything...Basically, I just ran Bulk Edit and changed the Error Greeting "After Greeting Action" for just ONE Class of Service.
As soon as we did this, Unity Connections completely stopped working. The Ports Answer but then drop immediately. The Event Viewer is filling up with these errors:
Event Type: Error
Event Source: CiscoUnity_PHGreeting
Event Category: Error
Event ID: 437
Date: 4/13/2006
Time: 1:50:34 PM
User: N/A
Computer: LKQUNITY01
Description:
An unexpected error occured while trying to play greeting for a subscriber. One possible reason could be that the call was disconnected while waiting for the phrase. This can happen when the Unity system CPU is pegged. Technical details - (PersonalGreeting) greeting for call handler id (null) with alias . returned [0x80004005] on line 1164 of file .\PHGreeting.cpp.
Bulk Edit on regular Unity servers has never caused me any issues in the past.
6 Replies 6
adignan
Level 8
Level 8
Event Type: Error
Event Source: CiscoUnity_Wav
Event ID: 801
Date: 4/13/2006
Time: 1:50:34 PM
User: N/A
Description:
Cisco Unity's multi-media component has enountered a serious error.
EXPLANATION:
A serious failure has occurred on port LKQCCM-1 during wav media processing. Depending upon the severity of the failure, parties on this call could experience unexpected behavior or be disconnected. In some cases, further calls on this port will not be handled correctly.
TECHNICAL DETAILS:
Thread 0x000019AC had a Failure on Port LKQCCM-1 in AvWav
DESCRIPTION:
File: .\Wav.c(1999)
Method: WavPlayEx
Failure: call to WavOutOpen failed.
ok...don't ever connect to UC with Terminal Services in "Console Mode"....ouch.
Just be curious how did you trigger the console mode when using RDP. Did you click the "Remote Control" button while highlighting the Console icon in the TSM window OR you use the command MSTSC /console?
I want to ensure there is no other way to do so. Thanks.
I have the same issue on Unity Connection,After restarts it works fine.
This happened soon after i modified a call Handler.What TAC adviced?
Rgds
John
Yes My problem is resolved. I have unchecked the "connect to console" optin in RDP.
Thanks alot.
prasanth_k
Thanks alot.
