Unity Connections7.02 Forwarding to Call Handler
jim.rowlan
I'm trying to find a good solution to a problem with call handling. Currently, if someone is not available, we have an option to forward a call to an attendant line (Press "0" for an operator) using a call handler. The problem arises when an operator isn't available. I'l like the call to revert back to the original mailbox.
     Inbound call goes to VM
     Caller presses "0" for an oerator
     Call goes to a call handler which attempts to transfer to an operator
     Operator doesn't answer
     Call drops
What I want:
     Call reverts to original caller
Any ideas?
Jim Rowlan
Ginger Dillon
Hi Jim -
Just a thought for you, is the Operator a voicemail subscriber?  Instead of sending to a call handler message when pressing 0, you could send the caller to the Operator subscriber, "Attempt transfer for".  If the operator is not available, the caller can leave a voice message.  The default behavior is to route the voice message to the originating called number, not to the Operator.  This may help?
Sincerely,
Ginger
Hi Virginia
Hope all is well my friend! +5 for this good thinking.
Cheers!
Rob
