Unity Dirt - 3.1.5
adignan
Level 8
Level 8
Changing Unity Servers, just moving 3.1.5 to another 3.1.5 server, does Dirt grab the following info:
1. Delivery Locations
2. Switch Info (Integrating to Nortel)
3. It appears that Passwords should be kept as well from reading the Dirt Release notes.
lindborg
1. yes - all location info is kept around.
2. No, your switch configuration needs to be setup when you install Unity - DiRT does not pull over your switch info from the restore. In many cases when folks are moving domains and such they are also moving switch setups (i.e. going from PBX to IP) so I don't make any assumptions there.
3. yes, passwords are preserved.
