1. yes - all location info is kept around.
2. No, your switch configuration needs to be setup when you install Unity - DiRT does not pull over your switch info from the restore. In many cases when folks are moving domains and such they are also moving switch setups (i.e. going from PBX to IP) so I don't make any assumptions there.
3. yes, passwords are preserved.
