Unity export of how caller input is programmed
hsmeyer
I am trying to export data of how "Caller Input" is programmed for each user, and each call handler.
How can I do this?
2 Accepted Solutions
5 Replies 5
This works great for Call Handlers.
Now I still need the same information for each User with a Mailbox
It ends up being a two step process
1-for Call Handlers
2-for subscribers
By user both of the accepted solutions I was able to get the information I needed
You could also use the COBRAS Export tool from dump the configuration in an Access database. Those are available on http://www.ciscounitytools.com
