Unity Port Utilization
Brad Pajari
Is there and easy way to pull port utilization for Unity that can be exported into Exel or even to a graph?  I seem to only be able to pull from CUCM for 30 days and for 5 ports at a time. Unity report also seem limited. Any ideas?
Rob Huffman
Hi Brad,
Have you looked into this tool;
Port Usage Analyzer
Overview
The Port Usage Analyzer tool is a suite of 4 reports designed to give administrators a better idea of the call traffic loads their Unity servers are experiencing.  Reports are generated in a graphical chart style for easy analysis and can also be saved in simple CSV files if desired.
http://www.ciscounitytools.com/Applications/Unity/PortUsageAnalyzer/Help/PortUsageAnalyzer.htm
From the awesome Unity Tools Suite
Cheers!
Rob
