Unity - Public Distribution List problem!
hoanghiep
Hi all,
I have a problem with Unity Public Distribution List: I couldnot Add or Remove subscribers to/from the lists (the radio buttons are disabled).
Could you please explain this and give me some workaround?
hoanghiep
Jaime Valencia
what account are you using when you login?
also unity version? (please always provide versions)
javalenc
if this helps, please rate
java
When running Permissions Wizard and Message Store Configuration Wizard you need to check the boxes to allow permissions to create DLs
Randy
Thanks for your responses!
The version is 5.0. I logged in Unity with the administrator account (unityadmin)
I can create PDLs but cannot add users to the lists or remove users from the "All user" list.
regards,
hoanghiep
