Unity : Transfer a call and transfer to another handler if it failed
Hi !
The customer want this scenario :
someone calls the receptionist No 100
-> message " I am busy please wait"
-> unity try to transfer to 100 4 times
-> after 4 times, transfer to an IVR.
I thought to make 4 handlers
-> receptionist busy
-> message " i am busy ..."
-> try to transfer to 100
-> failed -> transfer to Call Handler 2
Call Handler 2:
-> message "i am busy ..."
-> failed -> transfer to Call Handler 3...
I tried this :
Call Handler 1 :
call transfer : yes to 100, supervisor transfer
greetings : "the audio file", after greeting send to Call Handler 2
It works : call handler 1 -> call handler 2 -> ...
but I don't try to transfer to 100
Do you have any idee ?
thanks you in advance
Thierry
lindborg
Without seeing your configuration I can't be sure but my best guess would be that you have call handler 1 setup to "send to greeting for" call handler 2 instead of "attempt transfer for" call handler 2. This is a common mistake.
What you describe is certainly doable in Unity - I'm guessing it's a simple configuration issue.
