Unregistered FXO/fxs port on a newly configured MGCP gateway in CUCM 8.6
sarimirfan
I just configured a MGCP gateway in Call Manager. I also configured one of the two FXO ports available of the gateway and upon restarting the gateway and the FXO ports in Call Manager, the FXO port is  receving an IP address status unregistered. FXS also get IP address but status is reject.
I am doing this for the first time and I really appreciate if you could help me with a structured troubleshooting process. I could have missed something to configure during the initial setup.
thanks
You only have half the HW you need, you have the card, but no PVDMs to use them...
Buy PVDMs and then simply add the port to the DP.
java
if this helps, please rate
11 Replies 11
Andrew West
Level 4
Level 4
Have you created the dial-peers for your ports on your gateway?
Assuming everything else is configured right that should do it.
I just upload my running configuration can you check for me what I missing .
thank you
Terry Cheema
Attach a show run from the voice gateway.
-Terry
uploading my (show run) configuration...
thank
Add the actual port you want to register under DP 4, repeat as necessary
java
yes I would like to register under DP 4.
thank you
You said its FXO and FXS ports. But your gateway config shows no voice port.
Can you post the output of two commands:
sh inventory
sh diagnostics
-Terry
I just posted can you take a look for me .
thank you
java
Mazzy Star
can you give a:
sh ccm-manager
I just upload my ccm-manager configuration
