Unused endpoints
themizzz21
Is there any way to find endpoints that are unregistered for more than X days?
X could be any integer number greater than 4.
(Cisco Unified CM Administration System version: 11.5.1.22900-28 )
Thank you.
From CUCM 12.an see the last restoration status on the phone phone page. Those information is  controlled by a Cisco RIS Data Collector service parameter called RIS Unused Cisco Callmanager Device Store Period
The below link will be useful for you.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200578-Monitor-Cisco-IP-Phones-Using-Call-Manag.html
Response Signature
Sadav Ansari
From the RTMT you can see the unregistered phone details.
Device Search>>Phone>>Status: Unregistered>>Model: Any
Pls rate if its "Helpful". If this answered your question Pls click "Accept As Solution".
Sadav Ansari
themizzz21
Thank you for the replies,
Maybe I didn't ask the question correctly. I am interested in finding devices that have been unregistered for more than a month.
I think that by default, after three days in which a device is unregistered, it is declared as 'none' by the Call manager. Since the cluster is on version 11.5, is there such a possibility?
Regards.
You would need to parse the output, but you may be able to get the information you want with this command.
show risdb query phone
