Upgrade CUCM Cluster with encrypted calls
Hi!,
     We have a CUCM Cluster (one pub and two subscribers) in 11.0.1.22900-14. Due to the EOS of this version we need to upgrade to 12.5. As I read in the compatibility matrix, this jump is a "Direct Refresh".
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/12_x/cucm_b_compatibility-matrix-cucm-imp-1251.html#reference_67BDD7CCD5E79B2A974B1EFAE4FD15B9
My Only Concern is that the cluster is configured with "encrypted" calls, the encrytion was configured with the two USB sticks containing the security tokens.
QUESTION: Do I need to make some extra task in order to upgrade my encripted cluster? the calls will remain encrypted after the upgrade?
Thanks in advance,
Jaime Valencia
No, all the certificates and CTL remain untouched by the upgrade process.
Make sure to thoroughly read:
A) Upgrade Guide
B) Release Notes
C) OVA README/RN
All for the target release for everything you need to know regarding the upgrade.
java
if this helps, please rate
Jaime Valencia
A) Upgrade Guide
B) Release Notes
C) OVA README/RN
java
