Upgrade failure Unity Connection 10.5.2 to 14SU1
VON CLAWSON
Level 3
Level 3
Having an issue upgrading Unity Connection from 10.5.2 to 14.
The first time I tried I got the error "an unknown error occurred while accessing the upgrade file"
I tried again after rebooting and got the error "premature end of file"
I thought maybe that the file was corrupted so I re-downloaded it and tried again.
Again I got the "an unknown error occurred while accessing the upgrade file"
I looked through the install log and found an error in there "<subscriber ip> must have the primary server state for exporting of CUC data to succeed"
So I made sure that the subscriber was primary before starting. this last one said there were no error messages.
Attached are the install logs.
Please rate if this helps.
Did you ever find a solution? I have the same issue
