Upgrade from 4.1 to 7.1.5 - DMA - Extention Mobility problem
hguner
We're gonna upgrade our cluster from 4.1 to 7.1.5. The question is ,we have around 10,000 users with extention mobility (EM),
Is DMA gonna export user-logged-in information , as well? So that, when the upgrade process is done, no one needs to log into the phone again?
I found a couple of documents saying that
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f3307.shtml
CallManager 4.x to 5.x/6.x Upgrade Fails Due to DMA Error
Note:
Before you start the DMA backup, make  sure that ALL Extension Mobility Users are "logged OUT". If any of the  users are logged into Extension Mobility, the DMA backup will not  succeed.
Release Notes for Cisco Unified CallManager Release 5.0(3)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/5_0_3/503cmrn.html
DMA does not export the last user-logged-in data for CallManager 5.0.3.
But these documents do not show that problem for ver 7.x.
Any help would be greatly appreciated.
Guner
dakeller
Guner,
Having reviewed this request, I believe that the information you found is accurate. You must have the users logged out of EM, do the DMA backup, then upgrade the cluster.  Once the upgrade has completed, the users must log back into EM.  Besides asking the users to log back in, do you have a concern about the upgrade process?
Dan Keller
Technical Marketing Engineer
