Upgrade virtual machines when upgrade ESXi ?
Clement BONNAL
I just upgrade be6k from vmware 5.0.0 to 6.0u2
I plan to upgrade cucm/cup/cuc from 9.1 to 11.5
I would like to know if I need to upgrade virtual machine hardware from 8 to 11??
What are benefits/risks balance ?
Thank you!!
Hi Clement,
You might find your answer here.
Please rate if helpful and mark correct if answers your query.
Adarsh Chauhan
Please rate and mark correct if helpful
Adarsh Chauhan
Jaime Valencia
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements#Virtual_Machine_Version_.28vmv.29
java
if this helps, please rate
Hello Jaime,
I read this page and all other docs related, but no advice about changing VMVersion when changing ESXi version.
Hi Clement,
Adarsh Chauhan
Adarsh Chauhan
Ok I guess Cisco will not ask for 4000GB memory in its VM. Uh, finally I'm not sure....
So I will keep backward compatibility with vm8 version, because I don't want change hardware for fun, Vxnet3 adapter is enough deep change for today.
Thanks.
