Upgrading from 8.6 to 10.5 - LDAP Authentication will not work
Emily Sharrard
We are upgrading from 8.6 to 10.5.  Ldap synchronization and authentication are enabled.  LDAP Syncronization works just ine.  LDAP Authentication works fine on 8.6 Call Manager, but fails on 10.5.  The configuration in 10.5 mirrors the configuration in 8.6
For example, I can log in using a network credential to my 8.6 CM Administration Page, however using the same network credential on 10.5 authentication page it fails.
My network credential is sync'd in Call Manager.  I have assigned myself every possible permission call manager offers.
What am I missing?
10 Replies 10
Jaime Valencia
What LDAP are you integrating to?
java
if this helps, please rate
Microsoft Active Directory.
Everything was copied over using PCD. I did validate ports and that SSL was checked. And of course the Authentication was enabled for users.
What version??
And did you have a secure LDAP integration???
Or using wildcard certs on 8.6??
java
Which version of Active Directory? 6.1
I took a look in Cert Managment, looks like they are not self signed.
do you get any error?
is the Cisco dirsync service activated, try restarting the dirsync service and see if it works.
there could also be an issue with the wrong search-base entered.
"Log in Failed - invalid user name or password" We all get it. I am thinking it is a firewall rule or an ACL. I have tossed it over to that team to investigate.
Are you using TLS and/or wildcard certs??
java
Figured out the issue.  Needed the FQDN versus IP address in the LDAP authenticaion configuration.
Emily Sharrard
Figured out what the issue was. 10.5 was expecting the FQDN versus the IP address of the LDAP Servers.
