10-31-2011 01:32 PM - edited 03-19-2019 03:52 AM
Hi all,
I am upgrading my UCM cluster to 7.1.5.33900-10 and I know that when I do all my phones will reboot and upgrade to the latest firmware. My question is will my VG224 devices do the same?
BR
10-31-2011 01:53 PM
Looks like either:
15.0 or 12.4.24T. Its more of an IOS version, not so much an issue on CUCM itself. If your IOS is up to one of the levels mentioned, you should be good.
12.4.24T is for 7.1.5
15.0 is for 8.0 and above.
So take your pick.
10-31-2011 01:56 PM
What I mean to ask is when I upgrade the phones will automatically upgrade if they see a newer version. I would like to know if the VG224's will do the same. I thought it wouldn't be automatic, but I thought I would check just in case.
10-31-2011 02:05 PM
Your VG224 should be fine if your IOS level is what I recommend. Im not sure if your configuration is H323, MGCP, SCCP, etc. There may be a CallManager server version that you might need to adjust as well.
http://www.cisco.com/en/US/docs/routers/access/vg202_vg204/software/vg2_vg4_voip_ps2250_TSD_Products_Configuration_Guide_Chapter.html
Tommer Catlin
Senior Collaboration Architect
ePlus Technology, inc.
1376 Borregas Ave.
Sunnyvale, CA 94089
p.408.220.1846 (Direct)
c. 415.845.9329
e.tcatlin@eplus.com
Cisco Designated VIP 2011
www.eplus.com<../../../../../../Documents%20and%20Settings/lmarcum/My%20Documents/emails/www.eplus.com>
The information contained in this electronic transmission and any attachments hereto may be considered proprietary and confidential. Unauthorized distribution of this material to anyone other than the addressed is prohibited. Any disclosure, distribution or use of this transmission for any reason other than their intended purpose is prohibited.
