USB eToken status after installation
islamahmed
One question please,
Regarding the USB eToken, I used my PC to install the two USB security Token using the Cisco CTL Client.
the question is after installation and everything is ok, I must keep the two USB eToken connected to my pc or the server permanently?? or I can remove it ??
ISLAM
will.alvord
Level 5
Level 5
You should remove them and store them securely and separately.
Thanks for your reply
