Use of Pre-existent SSL Certificate for Express Way
Hello everyone.
    I wonder if anybody knows if it is possible to use a pre-existent SSL certificate for Express Way Server and Client.
    A third Party Trusted Authority issued an *.theCompanyIWorkFor.com ssl certificate. I've got all the files: private key, csr, crt and key issued by the provider.
    Is there any way to use all that instead of issuing a new csr from the server?
    It would be convenient regarding the fact that we had already bought that ssl certificate for a couple of years.
Thank you very much.
Bests regards.
Diego.
Chris Deren
No, wildcard certs are not supported on Expressway.
