VCS-C and VCS-E Deployment
Ajin Skariah
I want to deploy VCS-C and VCS-E for Cisco Jabber internal and external use. I have seen few documents and is very confused. Can someone help me in deploying it as simple as possible?. I have to configure VCS-C and VCS-E, and I have single Fortigate firewall. Any help on this is highly appreciated.
Thanks & Regards,
Ajin Skariah.
Jaime Valencia
There is just one document you need for MRA, and that is the MRA config guide, which is available under the VCS docs.
If you want it as simple as possible, you would need to use the same domain internally and externally, to have EXP-E signed by a public CA, and use dual networking in EXP-E.
All the config and the ports are in the guide, have you already reviewed it??
If not, that's your first step, if you have, what are the specific questions you have?
java
if this helps, please rate
Jaime Valencia
java
Thank you Jaime. I'll do that. Do you have any step by step document which you can share for VCS configuration for different internal and external domain with a single firewall.
Ajin.
Aside from the general MRA config guide, you can review this doc
http://www.cisco.com/c/en/us/support/docs/unified-communications/expressway-series/117811-configure-vcs-00.html
java
