ViewMail 4.x compatability with Unity 7.x
maratimer_2
Customer is running Exchange 2003 with Outlook 2003 on XP SP2 Desktop. Will the current installation of Viewmail 4.x work with the upgraded Unity 7.x or MUST they upgrade the workstation environment before upgrading the servers. Thanks.
culittle
This is the compatibility matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cuclientmtx.html#wp127632
I don't see that they specify the version of viewmail. So it should be supported.
Actually the matrix "does" indicate supported versions of Viewmail for Outlook (VMO). For Cisco Unity 7.0(2) only VMO version 5.0 and 7.0 were tested and supported.
Thanks for the post!
