Viewmail for Outlook 2010
bergquist
We are soon to be upgrading everyone to Office 2010 and according to Cisco TAC, they said that it is not supported yet. Has anyone been able to find a work around for doing this?
We are using Windows 7, Unity 7, Viewmail 7 for Outlook 2003, and Exchange 2007.
When I upgraded my (as well as a couple of other client machines) Outlook from 2003 to 2010, my viewmail still works, but I am unable to find where to configure/change any settings. On a new install of Office 2010 and Viewmail, I can therefore not find where to configure VMO.
Can someone please suggest how we will best be able to listen to VM via Unity/Exhange with Outlook 2010? I'm assuming there must be a way that the messages will still appear in the Inbox, but we can use Windows Media Player to listen to them?
But in that case, we will not have a WMI on the phones and the messages won't play from the phones? Please let me know if I am not understanding this correctly as it will be a major pain for our office.
Thank you.
5 Replies 5
skilambi
The only supported way is to move to Uconn and with 8.5 you are removing the UM gap with Unity so I doubt if VMO will ever be supported anymore for Unity with 2010. You can see this but it won't be TAC supported
https://supportforums.cisco.com/message/3120419#3120419
Srini
Thank you. I'll check it out.
See here for..Cisco is planning to release update for VMO for Unity for Outlook 2010 which is good news
https://communities.cisco.com/message/62883#62883
Srini
I cannot access the above  post.  Is Cisco still planning to release VMO for Unity for Outlook 2010 client?
Matt
Yes it is released for Unity and also now has TRAP support
Srini
