Voice gateway routeur requiement &for SIP connectivity
netautolearn
Hello team,
We have a router C8200L and we would like to use it as a voice gateway.
And we would like to use a SIP conncectivity with the telecom operator.
We would like to know what is the requirements (licence on router side, ...) we have to get.
Thanks for all
b.winter
You need 2 types of licenses for the router:
- a DNA license
- SIP Trunk licenses
For DNA license, depending on the features you use, you need one of the following:
For SIP Trunk licenses: You need to buy the same amount of lics as for how many concurrent calls you wanna support / or you expect.
E.g. if you wanna have max. 60 concurrent calls, then you need to buy 60 SIP trunk licenses.
netautolearn
Thank @b.winter
