VoiceMail Behavior with Cisco unity connection 11.x
Chrysostomos_CY
Level 5
Level 5
When the call going to unity and opening the greeting when the greeting finished asking you  to leave your message ..
iF you press any button then it started to announce some choices . For example its ask if you want to send your message press ,,, or if you know the extension press ,,,,
I want to remove any choices while the caller is at the state to leave a message ...
is that possible?Only for a specific voicemail nummber
/cc
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Aseem Anand
You can try browsing to:
CUC administration >>> Users >>> Select the user >>>> Edit Message Settings >>>> Play After Message Recording >>>> Do not play recording and set after message action to hang up
Let me know if it helps.
Aseem
