vwic3-2mft could not download P4SM RESET RELEASE
sylvain2006
Hi all
I have my voice gateway C2901, when i install a vwic3-2mft -t1e1 card, router do not recognize it.
But with sh inventory command, i notice that vwic3-2mft card appear.
With console log i have this error
*Dec 1 08:49:50.495: %PVDM-6-UNSUPPORTED: Codec G.723 is not supported on PVDM3.
*Dec 1 08:49:57.871: Could not release P4SM reset, MISC_CONTROL(0xFFFFFFFF)
*Dec 1 08:49:57.871: %HWIC_T1E1-1-FPGADNLDFAIL: HWIC_T1E1 0: FPGA download failure; could not download P4SM RESET RELEASE.
command sh inventory
NAME: "CISCO2901/K9", DESCR: "CISCO2901/K9 chassis, Hw Serial#: FGL173221HB, Hw Revision: 1.0"
PID: CISCO2901/K9 , VID: V06 , SN: FGL173221HB
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 1", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1 , VID: V01 , SN: FOC172873U2
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32 , VID: V01 , SN: FOC19127KQS
NAME: "C1941/C2901 AC Power Supply", DESCR: "C1941/C2901 AC Power Supply"
PID: PWR-1941-2901-AC , VID: , SN:
Interfaces that appear
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FGL173221HB
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License package
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data None None None
IOS
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M4.bin"
Can Someone help me?
If possible try a different VWic card.: good solution
10 Replies 10
I have my voice gateway C2901, when i install a vwic3-2mft -t1e1 card, router do not recognize it:- what you mean by not recognising? Since you can see it on show inventory the card is recognised.
You need to use card type command before configuring the controller
The T1/E1 HWICs or network module will not be operational until a card type is configured.
SUMMARY STEPS
1. enable
2. configure terminal
3. card type {t1 | e1} slot subslot
Response Signature
Card type command doesn't work
command card type isn't supported with
(config)#card type t1 0 2
% Invalid input detected at '^' marker.
Did you tried a reboot.. reinsert the card and reboot.  check if it makes any difference.
Response Signature
Did you tried a reboot.. reinsert the card and reboot : yes but nothing
and i uploaded a new ios but nothing
https://quickview.cloudapps.cisco.com/quickview/bug/CSCua50697
Have a look on above bug ID
Response Signature
@sylvain2006 why did you mark your own reply as the answer when it was really @Nithin Eluvathingal that gave you the correct answer?
Response Signature
@sylvain2006 why did you mark your own reply as the answer when it was really @Nithin Eluvathingal that gave you the correct answer? :  It's an error
If it was an error why do you not change it?
Response Signature
When i said It's an error:  i wanted to say that i was wrong
But i didn't want to give myself the solution
